Diesel Forum - TheDieselStop.com - View Single Post - DESPERATE!!! turns over with no start.
Old 07-03-2009, 10:10 PM   #49 (permalink)
ArrowHeadJim
It all in the terminologies, I guess it's a header. the rear oil cooler header.
NOT a housing.
But you knew what I was talkin about.
Just for reference I have the oil pressure spec's
Curb idle 10psi min.
40-70 max @ 3300 RPM
And the pump spec's
Drive gear radial clearance (0.028-0.032) inches.
Drive gear end clearance (0.001-0.003) inches.
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
ArrowHeadJim is offline   Reply With Quote
