On the driver side there is a big nut with a screw sticking out of it, That is the band adjustment. Loosen the nut,screw in the screw,5/16 open end, till snug then back out 1/2 to 3/4 turn. If that gives you second look up the spec and adjust by the book.
If it never gets snug the band is either broken or burned . If it is snug and still does not work there is a 4 bolt cover on the pass side, there is a rubber piston in there and it could be torn, cooked, or the wrong one. Also the band links could have fallen in the pan.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
PM please not visitor message
