Diesel Forum - TheDieselStop.com - View Single Post - Used f-350 with lift for Towing 5th Wheel
Old 07-04-2009, 04:51 PM   #2 (permalink)
BTBBT
My Photos: (19)
I've got about 4-5" lift and tow a gooseneck but I don't think I'd try a 5th wheel. What size tires are on it? Has the gearing been changed?
As far as dropping it back to the ground that wouldn't be too hard. I guess it depends on what type a kit it has.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
