Diesel Forum - TheDieselStop.com - View Single Post - ATS ported compressor housing
Old 07-04-2009, 04:57 PM   #31 (permalink)
BTBBT
My Photos: (19)
The ATS housing works great to eliminate surge. And yes I took off the WW and put the stock one on and it does seem to do better. I have hit 24psi with Jody's 80T and a DIY air filter. I couldn't do that with the WW. I sure tried though.
Once you get the new housing, you will see what I mean by the inlet to the turbo is no bigger with the ATS housing than stock.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
