Diesel Forum - TheDieselStop.com - View Single Post - Low compression??
Old 07-04-2009, 08:20 PM   #2 (permalink)
nitrogen
nitrogen's Avatar
doesn't make a lot of sense for a guide to be that bad if you just finished replacing the bad ones. unless whoever did them missed changing one he should have done or screwed up one he put in. is there any possibility what you are hearing is a slightly damaged tooth on the ring gear for the starter. if one tooth was cracked off you might hear a pause as it comes past the starter
nitrogen is offline   Reply With Quote
