Yes the power steering pump is involved in the brakes also. It supplies the hydroboost unit. Sounds like you need a new pump (or fix a big leak somewhere).
EGR Valve:
Consult these three pages
1. http://www.backglass.org/duncan/ps60...l/ps60_009.jpg
2. http://www.backglass.org/duncan/ps60...l/ps60_038.jpg
3. http://www.backglass.org/duncan/ps60...l/ps60_037.jpg
http://dan.prxy.org/Truck/6L_bible_html/html/Page_032.html
http://www.forddoctorsdts.com/articles/article-06-12.php
6.0L EGR Maintenance and Cleaning (Write-Up) - Ford Powerstroke Diesel Forum
(Just remember to use Carb cleaner and not brake cleaner to remove the gunk)
To me it sounds like you have sticking vanes on your turbo also - you should be considering pulling and cleaning it. If the vanes stick, you can overboost and this jeopardizes head gaskets.
Turbo Info:
VGT turbo ABC's - Ford Truck Enthusiasts Forums
You need to post information on your truck - it helps in the troubleshooting.
Mark
