I have a picture showing the inlet, hopefully it is below.
I didn't have any issues with the casting. I also didn't have any issues with the actuator mounting tabs being in the wrong spot. It doesn't look as clean and professional as the stock housing, but it works.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
