So with the new LPOP what was the pressure??
Did you raise the rear end to submerge the pickup tube?
You do have some miles on the motor but...
I would not pull the motor Until I resolved that there is a good reason to do so.
Check the things you can in the truck. Often problems are a simple as a stuck releif valve. Unless you just want to rebuild it with all new parts and be done. That's alot of denaro and work. Make the appropriot tests to locate the issue.
Commmon Rob you can do this!
Jim
97  F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
