Thanks Nashville. Ok. I think I understand but have a couple follow-up questions. The way it's wired now the "battery charge", black wire from the 7-pt Bargman goes into the power distribution (under front of trailer) and straight to the interior wall switch. The "breakaway" battery doesn't receive a charge AT ALL. I guess they expected us to pull it out and charge it before every trip? Will the little battery be overcharged if you go on long trips?
Also, should I assume a relay/fuse is bad if the "battery charge" lead to the truck's 7-pt Bargman ISN'T hot?
Thanks.
John
