Originally Posted by jlau6888
How would a Dp Tuner affect a ZF 6 speed? Is the clutch the only thing i need to upgrade or do i need to work on the internals too?
The ZF6 is a HOSS tranny. It'll handle just about whatever you throw at it. The pilot bearing needs attention, because if it goes out, it will take the tranny with it, starting at the input shaft bearing.
Clutch is another story though. The stock clutch will go out quicker if you start drag racing, etc. If you're careful to get it fully engaged before romping on the go-pedal, it'll last a bit longer.
There are good aftermarket clutches available. SouthBend sells some good ones, but be aware that there's no such thing as an all-around clutch. Some are good for pulling heavy loads and others are good for daily driving. Call them up and ask what they'd recommend based on your driving style.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
