Our 7.3s consume much less air than small block gas motors that see high rpm.
I second the K&N naysayer- I would never put one on my vehicle.
It's a matter of physics- if the air filter stays the same size, but somehow can flow more air, something has to be traded off. That something is filtration.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
