Originally Posted by rob-08
ok the pickup tube is perfect, no cracks, front seal is fine, and the screen is clear. what now? the check valve? where is it located
Post #12 from STurbo: You may have a problem with the front cover,
You list '96 my, and I believe another member who had the same problem as you describe had found his de-airation valve had backed itself out.
If that happens it will bypass all the lube oil supply back into the pan.
I think the only way to verify is to remove the front cover, and I believe it was determined only 1996 my that had that style front cover
Randy
Midnight black '94
* F-250
* 4x4 * ZF-5 * 3:55 * cc/lwb *
RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
