Originally Posted by Fozz
It's a great mod! I just got back from a 400 mile trip, trans worked great. Never got above 200 (but I have two coolers up front), even on some hard pulls. I think I might have been close to Chuckster territory (central CA)? Paso Robles . A couple of long hard pulls on the northbound 101. Was nice having the engine braking coming back home. I also put in some lights, a red light when locked-up and a green light when 'normal'.
You were a little south of my area. I am up closer to Stockton/Sacramento.
M.L.S.C. Looks like I might do this mod when I get home and have access to my tools and stores that I know will have the stuff I need. A few posts back you said that I could just tap into the purple/yellow wire, but it might cause issues. I have decided that the other side of the country is not the place to find out the PCM puts it in limp mode, Thanks again for all your help.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
