Diesel Forum - TheDieselStop.com - View Single Post - steering gear box/ Pitman arm
Old 07-07-2009, 11:41 AM   #12 (permalink)
aposak
I checked the AZ part numbers. The '95 F-250 is a 7516, and the '97 F-350 is a 7555 (and special order, ugh). There is a difference, but the housings also look different on the 2. Not sure what year you got your front end out of. Do your tie rod ends connect to the hub in front of or behind the steering pivot? I think that's the important clue here. Can check mine over lunch if you need a reference.
'95 F-250, 7.3L turbo DI, 4x4.
aposak is offline   Reply With Quote
