Diesel Forum - TheDieselStop.com - View Single Post - DESPERATE!!! turns over with no start.
Old 07-07-2009, 02:28 PM   #66 (permalink)
MX_STROKER
Wink
Originally Posted by rob-08 View Post
rick, i could not get to the pics of the de aeration valve
DE AERATION VALVE. Is this what you are talking about?
The valve is located inside the cam cover or engine front cover.
Be sure you have one:
Engines built with serial number 201681 through 375549 are equipped with the de-aeration valve.
Engines beginning with serial number 375550 were redesigned and did not incorporate the valve.
Look here for some pics.
IMAGE001 pictures from trucks photos on webshots
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline   Reply With Quote
