what would be the fusible links, the plastic piece bolted to the alt? I took that off and the truck still runs and charges then stops charging. Could the belt slip enough to do that, it only has 60000 miles on it. I took the belt off of the alt and the bearings sound really good(how do you release the tension on the belt?)
95 F350 4x4 XLT Lariat PSD E4OD 4:10 LS Camper package purch Mar 95 Command start, super chip(died),BD 3" downpipe & 4" cat back,cat cleaned, switched EBPV,shimmed fpr 76 psi,Homemade open air intake & HX hose,Pillar mount Autometer pyro boost & trans temp. gauges,Trucool 4590 B&M trans filter,Sparky AIC plus extra relay for command start,BFG AT 285/75/16. Western Wideout snowplow.
Wifes truck 2004 F350 CC 4x4 Lariat 6.0 L Auto 373ls 285/75/16 BFG AT adj. pedals,AIC camper package,Ford gold starter, Air Raid air filter.
99.5 F350 4x4 Lariat sc PSD Dually, command start, homemade open air filter,zoodad mod,6.0 trans cooler,DTT trans,Mag-Hytec trans pan,Pillar mount Autometer gauges, 4" stainless exhaust(chinese MBRP copy?),Aero 4040XL Muffler, DP Tuner F6, ATS ported turbo housing, Tightened wastegate rod, Boost regulator
