Thread: Batterys or alt
Old 07-07-2009, 10:35 PM   #6 (permalink)
2stroked
I couldn't get a ratchet or bar into the back of the tensioner so I used a stick to pry the pulley over and had the wife pull the belt off of the alt. Do you go at the back of the tensioner from the top or the bottom. After doing some searches I see some people use a ratchett strap down around the sway bar and up to tow hook. I had my tester on the battery while the truck was running and when the light came on the battery read 12 volts and was dropping.
95 F350 4x4 XLT Lariat PSD E4OD 4:10 LS Camper package purch Mar 95 Command start, super chip(died),BD 3" downpipe & 4" cat back,cat cleaned, switched EBPV,shimmed fpr 76 psi,Homemade open air intake & HX hose,Pillar mount Autometer pyro boost & trans temp. gauges,Trucool 4590 B&M trans filter,Sparky AIC plus extra relay for command start,BFG AT 285/75/16.
Wifes truck 2004 F350 CC 4x4 Lariat 6.0 L Torqueshift 373ls 285/75/16 BFG AT adj. pedals,AIC
heated seats,camper package,ESOF,tow mirrors,Ford
gold starter, Air Raid air filter.
99.5 F350 4x4 Lariat sc PSD Dually, command start, homemade open air filter,zoodad mod,6.0 trans cooler,DTT trans,Mag-Hytec trans pan,Pillar mount Autometer gauges, 4" stainless exhaust(chinese MBRP copy?), DP Tuner F6
2stroked is offline   Reply With Quote
