Diesel Forum - TheDieselStop.com - View Single Post - wont start
Thread: wont start
Old 07-08-2009, 12:39 PM   #2 (permalink)
Griz
Originally Posted by trcooll View Post
97 powerstroke turns over sounds like timing no compression history truck quit running put in new cam sensor no go new transferpump no go but turned over strong let sit for 2weeks tried to turn over nothing just click replaced starter still just click put in 2 new batteries still just click put on charger started to turn over but sounds like timing put on scan comes back as high pressure pump could this cause the motor to turn over like this
Have you checked the oil level in the HPOP? If not it should be within an 1" of the inspection hole.
Griz
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline   Reply With Quote
