Diesel Forum - TheDieselStop.com - View Single Post - Exhaust Brake for 6.4L
Old 07-08-2009, 01:04 PM   #29 (permalink)
bankspower
bankspower's Avatar
Originally Posted by wontonrunner View Post
Unless i missunderstood my manual when i read it, our 6.4 does already have assisted braking during the tow/haul mode. When in tow haul mode, when you brake the computer takes over and it controls your shifting and it modifys the exhaust valve timing to ensure your vehicle does not exceed a certain speed. I will have to look again and see if i can find it.
I know that if i am in tow haul mode...my truck will slow down on its own going down a grade when i let off the gas and tap the brake and it slows down a lot faster on level ground when i let off the gas and tap the brake as well.
The factory tow/haul setting works almost exactly the same way it does on the chevy. Blade position is brought down to a set point but it generates very little back pressure on the engine. In fact our testing on the stock setup was a mirrior image of the chevy run posted above.
On Edit: There's also a big warning on the Banks Speed Brake brake to NOT use it on the high strength setting with little or no load. It will nearly lock the tires up.
bankspower is offline   Reply With Quote
