Diesel Forum - TheDieselStop.com - View Single Post - wont start
Thread: wont start
Old 07-08-2009, 08:57 PM   #8 (permalink)
bugman
bugman's Avatar
My Photos: (18)
Is the HPOP draining out to where you have to refill it? No smoke means that the injectors are possibly not firring or the there is a problem with the HPOP system. On other possibility is that you have no fuel pressure to the injectors. You can check the fuel pressure on the drivers side of the filter housing. There is a scrader valve that you can put a air pressure guage on and check. I believe that you should have at least 50psi.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline   Reply With Quote
