Diesel Forum - TheDieselStop.com - View Single Post - Exhaust Brake for 6.4L
Old 07-09-2009, 10:52 AM   #31 (permalink)
wontonrunner
Originally Posted by bankspower View Post
The factory tow/haul setting works almost exactly the same way it does on the chevy. Blade position is brought down to a set point but it generates very little back pressure on the engine. In fact our testing on the stock setup was a mirrior image of the chevy run posted above.
On Edit: There's also a big warning on the Banks Speed Brake brake to NOT use it on the high strength setting with little or no load. It will nearly lock the tires up.
So then it is a turbo assisted braking deal and not variable valve timing then? Hmm, I learned something new today...it was a good day!
91 4runner. 1 ton locked and 40's
2008 F350 SD FX4
6.4TT
20" Jessie James 1 off rims
35" rubber
4" procomp lift
wontonrunner is offline   Reply With Quote
