It should be OBD II then. The only other problem is that PSD's don't follow "normal" OBD II protocols. They have there own, and you need the right reader or software to see if any codes are stored. Auto Enginuity is the software of choice here. I don't have it cause mine is OBD I.
Just for fun: here is a link to retrieve codes using the OBD I connector and an analog volt meter, can't hurt to try
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
