Cracked Head cause?
My 05 F550 service truck likely has a cracked head. If so what are the most common causes? Most engines will not tolerate low coolant levels, if the fire deck is not covered with coolant, BAM, cracked head.
What I'm wondering is I had the coolant changed a few days prior to the fuel in the cooling system showing up. How tricky are these to get the air purged out of? Could this be the cause?
Diesel Mechanic 28 yrs
