Diesel Forum - TheDieselStop.com - View Single Post - Recalled CPS Lose fuel mileage?
Old 07-16-2009, 12:45 PM   #15 (permalink)
xcr8oo151
xcr8oo151's Avatar
it is above the balencer under the water pump on the pass. side.it has a angle bracket on it used for timmeing.,if u want to change it do it when the engine is cold if possiable.use a 10m 6 point wrench to breck the bolt loose,then use a socket to un thread.
it's MY story and i can tell it anyway i want! 2000 F-350 7.3psd cc shorty 4x4 with intake,dp-tuner stock 40tow 80econ 140hp 5f switch mounted on the gauge pod, apiller tripple gauge's, trans temp,egt's,boost, tranny rebuilt with tugger shift kit,hd conv.,borg warner kit,4'" exhaust from the stock down pipe,5er and gneck hitch's in box,class five reciver out back,fire stone air bag's controled by a load controller on rear axle,onboard aircomp. under hood,2 2.5 gallon tanks under bed,air coupler in alum tool box in bed for tires etc....285/75/16 coopers, pioner jl adiuo kicker sound system,150,000 and going strong,psd's rule!87 f-250 6.9 4x4 auto bank's turbo ,4'' exhaust.soon to come, intake, ip and injecter's.installed a wrecker bed with wheel lift and recovery winch's
xcr8oo151 is offline   Reply With Quote
