truck completely dying after installing dp-tuner
earlier today I was installing my dp tuner and had to take out the pcm. but first had to unbolt the wiring harness from under the hood. at first I started taking out the 10mm bolt in the harness next to the one for the pcm then I realized it was the wrong one. after doing everything for the chip/pcm...I tried to start the truck. it started but then it would not shift out of park. I then re-tightened the bolt I had first loosened because I forgot to and then it ran and everything. but two times today, the truck had just stalled and other times itstarted sputtering and all the dash lights would come on and then itd be normal again. but when it stalled, there was no wts light or anything but the check engine light was on. so I went under the hood, moved that whole harness around and the wts light came on and it started right up. I don't want to be driving somewhere far or on the highway, stall and have to get out and move the harness around to have it start again. any ideas on what this could be? the harness I wasn't supposto touch was the one directly underneath the master cylinder. it has two 10mm bolts in it. both the bolts are tight now and it just did it on the way home. it almost sounded like it ran out of fuel when it stalled the last time and all the lights were on...including the wts light... and it wouldn't start. it would just crank over. so I went and moved the wire around and it fired right up. so I figured theres gotta be something that's not right...
2000 f350 crew cab short bed 2wd. Glowshift guages, magnaflow stainless exhaust, DP Tuner. paid 3,000 for the 245k miles it had. up to 260000......SOLD
1999 f250 ex cab short bed 4x4 K&N air filter DP Tuner (stock, 80 economy, 120 race, 140 aggressive, lope idle) 4in exhaust airbags autometer gauges built tranny 305k miles! -SOLD
1999 f250 ex cab short bed 4x4 350springs 170k built trans DP Tuner (stock, 60 tow, 80 econo, 140 aggressive) 4in banks exhuast glow shift guages 8ft boss plow
2003 f250 crew cab lariat 4x4 240k miles, 9'2'' BOSS V plow
2002 f250 crew cab lariat 4x4 355k miles, 8'2'' BOSS V plow
