Old 07-18-2009, 08:15 AM   #8 (permalink)
JimTJr
JimTJr's Avatar
My Photos: (6)
I also would try another fuel filter, since you have been running vegie,, maybe waxed up? Also, does it run absolutely TERRIBLE when down on power? Rattles, knocks, ect...? Like it's starving for fuel? Or just has no power? (But not terribly noisy from under the hood?)
Originally Posted by TonkaThunder View Post
These are the codes P232, P1247, P1211
P0232 Fuel Pump Relay Driver Failed Off -----> This is NOT a common code, you may have a fuel pump relay going bad, and causing you intermittent fuel pump problems, which your symptoms DO sound like to me.
P1247 Turbo Boost Pressure Low ----> Boost leaks?
P1211 ICP Not Controllable - Pressure Abow/Below Desired ------> Common with a chip,,, probably nothing.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 6pos chip, AC Stage 1 sticks, 4" Turbo back straight pipe/stainless 5" tip 131st B/W MoAirNatlGuard B-2 BOMBERS at WHITMAN AFB, Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline   Reply With Quote
