Diesel Forum - TheDieselStop.com - View Single Post - truck completely dying after installing dp-tuner
Old 07-18-2009, 11:38 AM   #3 (permalink)
woodnthings8
woodnthings8's Avatar
Also make sure you cleaned the contacts properly on the PCM where the tuner is attached. Something else to think about is when you slid the PCM into the plastic support the wires may have pulled the chip partially off the contacts. Pull the chip out and see if the truck runs "normal" then you can re-iinstall the chip. I cut a large portion out of the plastic cage to allow plenty of room for the wires on my F-6. It seemed to me, it was just to tight when sliding it in.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
