Diesel Forum - TheDieselStop.com - View Single Post - PCM code?
Thread: PCM code?
Old 07-20-2009, 01:26 PM   #5 (permalink)
calico5string
calico5string's Avatar
My Photos: (14)
Originally Posted by calico5string View Post
Your tuner should still work even if the PCM is reflashed.
Here's a pic of the different numbers:
I used to have a list of DPC numbers and all of the "code" numbers for each, but I can't seem to find it. If I do, I will post it up.
I found it!!
Here is the list of PCM "Family Codes" (Models) and "PCM Codes":
PCM Codes (Click ME!)
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline   Reply With Quote
