Diesel Forum - TheDieselStop.com - View Single Post - High Boost/Low Power
Old 07-20-2009, 08:14 PM   #10 (permalink)
bismic
Try rotating the EGR valve 15 degrees or so. I hooked up a fuel line handle over some heavy duty wire. I hooked the wire to the eyelets of the EGR valve (where the bolts went through). I then yanked up very hard and tried to twist it a little at the same time. It was hard, but it came out. It was nasty.
Mark
bismic is offline   Reply With Quote
