2001 Powerstroke 7.3 WVO Fuel System ???
I just got my new to me 2001 F350 7.3 this last weekend, after getting rid of my 96. I want to continue to run WVO and I what to inquire everybodys minds to my ideas for my new wvo system. I want to keep it simple, and here is my idea; please critique. Fuel tank in bed with hot fox pick up. ran to air dog gen II beside tank in bed. single supply line ran to engine compartmentrigh next to stock fuel bowl. Now there are two lines running out of the fuel bowl one for each head. I am thinking of splitting my single supply line and tapping into the stock two fuel lines, and putting a check valve just behind the connections so i do not get wvo into the diesel system. i will run hose on hose the entire lenght of the supply line back to the hot fox and insulate +wrap. When engine is up to temp just cut the power to the stock fuel pump, and switch to air dog power. This seems simple, effective, and not to expensive. I am estimating around $1000. 100 for semi junk yard tank. 200 hot fox, 600 air dog gen II. 100 check valves (2) and fittings plus heater hose. Please let me know what you guys think.
