Originally Posted by altaford
Well, no codes are showing up right now. Tried it with the small engine mounted fuel filter removed, wondering how much flow should be coming from the HFCM. There is definitely flow, but I don't really know how fast it should be coming.
On this 2005 with the ICP under the HPOP cover, where can I hook up a guage to check my oil pressure?
Thanks.
Your ICP is on the passenger side valve cover.
Mark
