Diesel Forum - TheDieselStop.com - View Single Post - Steering Play to left
Old 07-22-2009, 02:55 AM   #3 (permalink)
biofumes
biofumes's Avatar
Originally Posted by pwrstrokn2004 View Post
Jack up the front and grab the top and bottom of the tire and try to rock it back and forth. Also check panhard rod, drag link for wear. If your truck is lifted or leveled you might have to adjust the drag link to center the wheel.
I'm having a similar problem, so I jacked up my truck, tried to rock the wheel and the entire wheel with rotor has play in it, so much the rotor is rubbing on the brake clips that hold the brake pads in place and its eating away at my rotor. I did not see any play on the ball joints, and there is no vibrating or noises, just the visual rotor damage. I have a 4x4, Do I have to replace the entire hub assembly?
"I refuse to tip toe through life only to arrive safely to death"
37 Toyos on 22 Rims
4.56 Gears
Fox Shocks
8' Fabtech Lift
Triple disk torque converter
billet oversized trans pan
25K Husky Hitch
biofumes is offline   Reply With Quote
