need to check fuel pressure...anything under 45 psi is gonna give you lotsa problems. Fuel pressure is #1 issue for repeat injector failure. If BOTH filters have been replaced and fuel pressure is low, gonna need to check fuel pump and pressure regulator. May also have inlet restriction in tank also, but not very common on 6.0
