Firing out the intake is almost always a timing or wiring problem. Check the plug wiring with the firing order to be sure they are correct. Not sure about how to check the time on the new engines, but basic timing must be the same as it always was. Check with a timing light.
George
6/2011 F350 PSD Lariate, CC, 4x4, LB, DRW
06 Newmar Cypress 29KSRE 5th wheel/MorRyde IS, Kodiac Disc Brakes.
