Just an FYI - the EGR valve and solenoid is all one piece. They do not come separately. Also, if the CAC tube blew off or split significantly, I would think it would be pretty loud. Make sure the dealership gives you details. If they don't, then ask them how the failed part caused the injector and no-start problems.
Mark
