Diesel Forum - TheDieselStop.com - View Single Post - 6.0 starts sometimes...Help with troubleshooting
Old 07-24-2009, 08:15 AM   #4 (permalink)
bismic
You only have one fuel pump. It is part of the primary fiter. When you say you have oil pressure, are you measuring the high pressure oil? The dash guage is just the low pressure oil. You need 500 psig oil pressure to start. You could try disconnecting the ICP sensor and see if that helps.
You could also have wire chaffing.
Wire Chaffing Locations
http://www.***************.com/forums/attachment.php?attachmentid=17301&d=1208412696
note - "the diesel garage" with no spaces should be where the "stars" are.
FICM and ICP harness recall:
http://www.forddoctorsdts.com/photographs/index1.phphttp://www.forddoctorsdts.com/articles/article-05-13.phphttp://www.forddoctorsdts.com/articles/article-05-13.php
mms://multimedia.ford.com/seopts/Tech12_250k.wmvhttp://turbodieselforums.com/downloads/6.0L%20wire%20chafing.pdfhttp://turbodieselforums.com/downloads/Econoline%20Wire%20Chafe.pdf
Mark
bismic is offline   Reply With Quote
