Diesel Forum - TheDieselStop.com - View Single Post - 6.0 starts sometimes...Help with troubleshooting
Old 07-24-2009, 04:45 PM   #7 (permalink)
bismic
Originally Posted by FlyMarines09 View Post
would a quick fix of wire chaffing be just use some electrical tape? This truck needs to run! It's costing me toooooo much money just sitting and not running.
ICP - Injection Control Pressure (sensor). This is what reads the pressure on your high pressure oil system. It must sense 500 psig oil pressure minimum or your truck will not start. You can disconnect the ICP and your truck computer will sense that the ICP sensor is not functional and go to a default strategy.
Depending on how bad the wire chaffing is, you may just be able to re-tape and go. I have seen pics of bad chaffing and wires that have been burnt through. then you need to splice (or replace pigtails)
Mark
bismic is offline   Reply With Quote
