Diesel Forum - TheDieselStop.com - View Single Post - Steering Play to left
Old 07-24-2009, 10:04 PM   #6 (permalink)
bondsman
The ball joints are the two connecting points between the axle and hub area. That is what allows the wheels to pivot. The tie rod ends are what is connected to each wheel and the pitman arm. If you can wiggle the steering wheel and you see the rods moving but the wheels don't attempt to move then you need tie rod ends. The ball joints are bad if you jack the front end up, place a bar under the tire and lift up and watch the two pivot points and if you see any play, replace them. If you jack it up and lift the wheel with the bar, there is no movement in the ball joints but the wheel still moves up and down like it is loose, then you have to replace the hub assemblies. The bearings are bad and are not servicable themselves, you have to replace the whole hub assembly.
2005 F250 LARIAT CC 4X4 6.0L PARROT CK3200 bluetooth car kit, Shaker 500 system, nice set of train horns, twin viair compressors and 5gal tank, 5" MBRP turbo back, AFE stage II intake, SCT tuner.
1996 F350 AT, IDM and switched ICP mod
1995 F250 SC AT, IDM and switched ICP mod, 6" susp 2" body lifts.
1994.5 F250 SC 5spd 4x4 IDM and ICP mod
bondsman is offline   Reply With Quote
