Diesel Forum - TheDieselStop.com - View Single Post - coolant droplets...
Old 07-25-2009, 11:36 PM   #2 (permalink)
bismic
Run your truck with the level (when cold and depressured) at the minimum line on your degas bottle. Install a new degas bottle cap - Ford updated the design somewhat.
Keep an eye on the level, but expect it to fluctuate. It is a pressurized system - including the degas bottle. Hoses and such will expand and contract (as well as some volume expansion and contraction with temperature changes) - therefore the level will fluctuate.
Mark
bismic is offline   Reply With Quote
