Diesel Forum - TheDieselStop.com - View Single Post - 2001 Powerstroke 7.3 WVO Fuel System ???
Old 07-26-2009, 02:36 PM   #4 (permalink)
ajohansson
ajohansson's Avatar
ToddT,
Its been a while since we were bouncing ?'s off of each other. Sorry to hear your fass failed. Mine failed after a year and about 15k miles. Dan at DPP/FASS said it was an unknown premature motor failure. I was barely under warranty and they fixed it for free. He said they also upgraded the motor base at the same time. He said out of warranty it would have only cost like 100 dollars. So not to bad.
ajohansson is offline   Reply With Quote
