Just tell them that you need some Premium Gold Coolant, like this... Parts
I just installed a Dieselsite coolant filter also.Just make sure to use hose clamp pliers when you make your cuts and you'll be fine.I honestly only lost a dime sized drop of coolant.I've read some guys lost a ton and cannot understand why.Found these directions from another site and were a little better than the ones it came with. http://www.dfuser.com/Install%20Guid...filter_kit.pdf Good Luck.
 3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
