Load / Tire Inflation info
I weighed my 08 Crew Cab F350 srw V8 gas Lariat on the CAT scale at the local truck stop. The truck was empty, full tank, me inside this is what I got for weights
Steer Axle 4020 lbs
Drive Axle 3200 lbs
What tire pressures should I be running for the Goodyear Wrangler AT/S LT275/65R20E.
The center tread on the rears is almost bald at 14000 miles the fronts look brand new. Ford says 80psi in the rear and 65 psi in the front. You can't access the tire and rim assoc. charts any more on line. Like they are hiding something to sell more tires from premature wear from over inflation.
2000,F250SD,SC,PSD,4X4,SB,6SPD.TRADED 2002 F250SD,CC,PSD,4X4,6SPD.TRADED Both bone stock,NO cackle!Rotella T,Stanadyne performance additive every tank.2 out of 2 an't bad. 2004 F350 CC 6.0 Torque shift,4X4,TRADED. 2008 F350 CC4X4 GAS!!!TRADED. 2011 F350 CC Lariet FX4 Back to DIESEL
