Diesel Forum - TheDieselStop.com - View Single Post - Load / Tire Inflation info
Old 07-29-2009, 08:26 AM   #2 (permalink)
sergeantnic
sergeantnic's Avatar
I'd run 65 psi all the way around unless you are hauling. If you are hauling a load then add 5 - 10 pounds. Do you rotate your tires? You should be doing that every oil change or at least every other oil change.
sergeantnic is offline   Reply With Quote
