Diesel Forum - TheDieselStop.com - View Single Post - 2001 Powerstroke 7.3 WVO Fuel System ???
Old 07-29-2009, 12:09 PM   #12 (permalink)
ajohansson
ajohansson's Avatar
Leon,
His name is Jason not Jack and what I think Jason is saying is your site says your system is "similar to veggiestroke" when it should really say "based off the original veggiestroke design". Jason has put alot of hard work into his system and should be credited for that when anybody is selling a kit based on his design. Regardless of where you finally install the check valve its still a FN74 Veggiestroke design. Even the guys who built there own kit based off of Jason's original concept always say they are using a FN74 design. Be cool.
AJ
ajohansson is online now   Reply With Quote
