Diesel Forum - TheDieselStop.com - View Single Post - Load / Tire Inflation info
Old 07-30-2009, 08:16 AM   #6 (permalink)
sergeantnic
sergeantnic's Avatar
Originally Posted by tomallen View Post
Thanks for the info. I know that 70 80 psi in the rear is insane but that's what Ford insists on. I even have a letter from Ford that states I must maintain the the tire pressures in the door pillar at all times or the truck will shimmy out of control. The guys that have air sensors must have a real pain if they air down to a sensible pressure. Who is responsible for my ruined rear tires after maintaining the recomended tire pressures and the unsafe tread wear it caused?
I got that letter too. I can tell you my front end shimmy'd like crazy until I took the truck over to Walmart of all places and had them re-balance the tires. It has disappeared completely now.
Unless you got a tire warranty when you bought the truck you're pretty much SOL. Just make sure when you replace them you go with a local company that is going to offer some kind of warranty.
sergeantnic is offline   Reply With Quote
