Diesel Forum - TheDieselStop.com - View Single Post - Engine Temp. Issue in 04
Old 08-06-2009, 08:07 AM   #8 (permalink)
bismic
Originally Posted by new2deisel View Post
I would be happy if mine would stay below 230* while towing. Mine usually runs about 210* empty. Both EOT/ECT are within 5* of each other. I can get it up to 240* pulling my 16,000# toyhauler up grades. Mine is an 05.
Those temps are too hot IMO. Sounds like you have a water flow (or air flow restriction).
Mark
bismic is offline   Reply With Quote
