Diesel Forum - TheDieselStop.com - View Single Post - ccv mod question
Old 08-06-2009, 08:22 PM   #3 (permalink)
knoweigh
knoweigh's Avatar
Originally Posted by jcashtrucking View Post
i did this mod about 5 months ago, just ran the 3/4 tube striaght out by the rear bumper. the question i have is can i put a bong into my exhaust and have it run straight so it will be sucked out by the exhaust or will that hurt anything
yes many have done just that;
welded a bung in the exhaust near the rear and let er blow!
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline   Reply With Quote
