Originally Posted by new2deisel
I agree, but have not figured out what it is.. Oil cooler has been replaced. Egr cooler replaced. EGR Valve is welded shut and uppipe is welded. Replaced the thermostat. Did a coolant flush to make sure I had the correct mix. I have a custom grille but I do not see it preventing air flow. I am going out of town next week, I think I will take it off to see if it makes a difference.
How do you read the temps?
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors
, White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels
, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat
, amp research steps, sirius, '08 diff cover, redhead steering box,
, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
