Mechanical gauge will tell the story on the low pressure side. Have you pulled the oil filter out, pushed the black drain valve down with a screwdriver while having someone crank the motor? It should fill the housing with oil very quickly. If it does fill, assume the LPO system is ok and start looking for a massive leak in the HPO system. (Since you have already pulled the valve covers, I would take the HPOP cover off next) If it does not fill the oil filter housing, you have a LPO system problem. The first things to check there would be the oil pressure relief valve, and then the oil pump itself.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
