Diesel Forum - TheDieselStop.com - View Single Post - help! truck just up and died.
Old 08-10-2009, 11:59 PM   #12 (permalink)
Texascadillac42
Texascadillac42's Avatar
My Photos: (10)
I see, the o-rings on the stand pipes seem to be a pretty robust piece of rubber, unless you really worked at it, I think they are probably fine. And I dont know if a busted o-ring could cause a big enough leak to affect LPO psi. That check ball is roughly 1/2" in diameter. A 1/2" hole in the side of the HPOP will cause ALOT of oil to be pushed out of the pump without going to the heads.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline   Reply With Quote
